Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - T-400 modulator line
Old 04-11-2010, 05:31 PM
Crosley's Avatar
Crosley Crosley is offline
Global Moderator
Wiki Edits: 1659
Should be a port on the intake manifold for full vacuum to the modulator.
Vacuum needs to react to the engine load as the throttle is opened.. the vacuum drops to raise line pressure in the trans
