T-400 Modulator Plug - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-28-2013, 06:33 AM
First time rebuilding a TH400, completed most the mods that Jake usually recommends, (Dual feed, full fwd manual, 1-2 override, 2-3 accumulator, drilled plate holes at .125/.140 and did the boost valve mod) I plan to leave the governor out but want to know if the modulator can be left in with no vacuum applied or do you have to use a plug? Also, purchased a new B/W friction kit, it came with two different colors of frictions, there are browns and greens. I assume the green ones would go into the direct clutch pack? Thanks.
plugged vacuum modulator T-400 0trbo4myCHEVUICK Transmission - Rearend 22 10-26-2012 11:47 AM
Plug gap help please SBC 400 Fastest65 Engine 12 12-03-2010 03:58 PM
th-400 vac modulator rtyauch301 Transmission - Rearend 2 08-17-2010 12:03 PM
T-400 modulator line unstable Transmission - Rearend 8 04-12-2010 05:30 PM
T-400 Modulator or Governor Upshift? 454headache Transmission - Rearend 5 04-06-2010 04:48 AM
