T-400 no reverse
at the track friday night. 4th race of season. no trans problems as it was a brand new rebuild. on a qualifying run near the end of the quarter it felt like the trans was binding and stopped pulling hard. puked the type F trough the dip stick and smoked the track last 100 feet. anyway i have all forward gears no reverse. reverse manual pattern th400. 3800 stall. neutral is neutral park is park. Any ideas?
If 3rd gear is OK , the reverse problem would be the rear band.
At the Bonneville Salt Flats, first gear is known as 130 mph. |
th 400 issue
rear band had some wear, but the stupid check ball that tci gives you for the passage next to the center support got sucked up into the center support. replacing center support and using larger check ball.
| T-400 only reverse gear | chuck whitaker | Transmission - Rearend | 3 | 12-20-2012 07:08 AM |
| THM 400 will not move in reverse. | ikkinrolyat | Transmission - Rearend | 1 | 11-29-2008 04:11 PM |
| Turbo 400 reverse pattern...? Why...? | Bumpstick | Transmission - Rearend | 1 | 05-30-2005 05:56 PM |
| 400 turbo no reverse | 68chevelleSS454 | Transmission - Rearend | 2 | 08-25-2004 11:49 PM |
| New TH 400 slow into drive and reverse | Jmark | Transmission - Rearend | 2 | 02-09-2004 10:39 PM |
