T-400 with no speedo capabilities - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-10-2011, 06:18 AM
I see buy reading some of the posts on the th400 speedo blanking plug should in theory just knock out!! hmmm, my 400 came out of a amc fsj so was fitted with the plug or what looks like a plug but not in the tail case but as part of the tranny case, but when trying to knock out the plug gave up before i actually smashed the gearbox case to pieces it seems thar on my tranny that the plug is actually a cast part of the trans case and not a plug if i take the tail case of and put my fingers in behind the plug it does not feel like a core plug or some thing simillar need to get my head right in there for sure to see if its moulded part of the case but all i know is it is a tight fit anybody come across this??
Old 03-10-2011, 05:34 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
On some cases GM did not machine the speed-O area open.
Some were machined and plugged at a later date I guess.
GM may have not installed the core plug, perhaps a shop did on some replacement cases
Old 03-18-2011, 05:18 AM
Trans plug.
Some Oldsmobile T400's had the speedo hole plugged, they drove the speedo off the front wheel via cable' somewhat simular to early VW speedo cable drives. So I know they did build these that did not have a speedo hole. They did install 400's in many Jeep vehicles, I assume your AMC is a Jeep. They might have driven the speedo off the transfer case?
Old 03-18-2011, 07:40 AM
FSJ = Full Size Jeep
Damn TLA's (three letter acronyms) LOL
When you say smashed the case...you mean totally destroyed it or just chipped it up a bit?
Old 09-16-2011, 09:31 AM
sorry it has taken so long to reply, i tried knocking what looked like a plug out but after a little research and your answers realised that the plug was moulded to the trans casing after a couple of sturdy clouts with a punch i realised the hole would need machining to open up the speedo drive so i actually did not persevere any further with the said 2lb persuader lol so thankfully no chips or cracked case.
chevy 400 speedo question remist17 Transmission - Rearend 6 03-07-2011 08:48 AM
400 ford capabilities?? 427feracer Engine 10 01-02-2010 02:05 PM
TH400 with no speedo capabilities Slomotion34 Transmission - Rearend 2 04-22-2008 08:51 PM
TH 400 Speedo Gears rs67ss Transmission - Rearend 5 04-03-2005 11:58 PM
TH-400 Speedo Drive Gear Replacement 454impala69 Transmission - Rearend 6 03-17-2002 03:03 AM
