Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - T-400 not warming up
Old 05-24-2011, 03:45 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by ss396si
my t400 is not warming up to normal temps. It will only reach a temp of 130. It has a 10" convertor, 8 AN braided hoses, deep trans pan and a cooler.
If you are able to drive the vehicle, it's getting hotter than 130 degrees unless you have the all-time best cooling system ever for an automatic transmission.
I'd suspect the gauge or sender or its wiring, but an infrared thermometer will tell you the pan temp, or a quick test is to simply lay your open palm up against the tranny pan after a good drive- quickly feeling for heat. 130 degrees will be easily tolerated for a moment.
