Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - T-400 not warming up
Old 05-24-2011, 04:57 PM
tnsmith10's Avatar
tnsmith10 tnsmith10 is offline
when will it rain???
Originally Posted by ss396si
my t400 is not warming up to normal temps. It will only reach a temp of 130. It has a 10" convertor, 8 AN braided hoses, deep trans pan and a cooler.
are you running the trans cooler lines through the radiator along with the aux. cooler? if not, as long as your moving, the trans isnt likely to build a whole lot of heat.
if you are running the cooler lines through the rad before the aux. cooler, then like cobalt said, within roughly 20 miles, the trans should be about the same temp as the engine.
