T-400 not warming up - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-24-2011, 02:32 PM
ss396si's Avatar
my t400 is not warming up to normal temps. It will only reach a temp of 130. It has a 10" convertor, 8 AN braided hoses, deep trans pan and a cooler.
Old 05-24-2011, 02:45 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
If you are able to drive the vehicle, it's getting hotter than 130 degrees unless you have the all-time best cooling system ever for an automatic transmission.
I'd suspect the gauge or sender or its wiring, but an infrared thermometer will tell you the pan temp, or a quick test is to simply lay your open palm up against the tranny pan after a good drive- quickly feeling for heat. 130 degrees will be easily tolerated for a moment.
Old 05-24-2011, 03:57 PM
tnsmith10's Avatar
when will it rain???
are you running the trans cooler lines through the radiator along with the aux. cooler? if not, as long as your moving, the trans isnt likely to build a whole lot of heat.
if you are running the cooler lines through the rad before the aux. cooler, then like cobalt said, within roughly 20 miles, the trans should be about the same temp as the engine.
Need help warming-over a 78 350 JMSTOY Engine 1 12-27-2011 09:00 PM
global warming........again pepi Off-Topic 8 07-19-2008 07:24 PM
Global Warming? 428ho Off-Topic 16 05-03-2007 07:13 PM
Global Warming Blazin72 Off-Topic 30 05-29-2006 02:58 PM
warming up the shop PrimeMover Garage - Tools 8 10-14-2003 09:58 PM
