T-400 Numbers - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-17-2011, 01:26 PM
T-400 Numbers
I've got a Chevy TH400 that I bought this thing 20 years ago, so there's no telling what it came out of. While trying to clean up the grime to read the codes stamped on it, I found a big "11" near the bellhousing rim, drivers side. What does this mean? I've seen pictures of them with other numbers (or even letters), so I figure it must mean something.
Old 06-17-2011, 02:01 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
IIRC, it's a casting/foundry ID ofsome sort. I've not heard of it being used as a "tell" for ID'ing a tranny.
There are some stamped-in numbers on the pan rail that are a partial VIN/engine ID IIRC, and there are riveted on tags that can be used to decipher some of the info on it.
Example:
TH400 ID TAG
Old 06-18-2011, 08:42 PM
Thanks, cobalt. I cleaned off enough of the grease to be able to read the riveted tag (I haven't found a stamped VIN yet).
It's a pink () tag with the big "C" and "W" on it.
The serial number reads:
79-CW 19403 across the bottom.
There's also a "557" stamped into the tag higher up.
I gather it is something from 1979, but have no idea about the rest.
Time to bust out more degreaser I guess.
Old 06-18-2011, 08:57 PM
SSedan64's Avatar
79= Year
CW= Model, I don't have the Model code list.
19403= Serial #
557=?? should be the Julian date "Day of Year" but there aren't 557 days in a Year.
Model code list would look something like this but, for TH400>> http://th350.netfirms.com/pages/7a2-71.jpg
Old 06-18-2011, 09:06 PM
I finally found a list, if anyone else runs into the same problem.
I can't be sure as to its correctness, but hey, it's on the web...
http://www.teufert.net/trans/t-400.htm
It looks like my tranny comes out of a GMC truck...Series 10.
Old 06-19-2011, 02:38 AM
SSedan64's Avatar
GM Trans Codes, ID, Speedo, Info
Good find there, also has TH350 codes & other Info as well.
http://www.teufert.net/trans/tranny.htm
Old 06-19-2011, 06:48 PM
Oooh, I didn't see the stuff for all the other trannys....awesome. I'm definitely bookmarking that.
One thing about my TH400 is it has the 4" snout. I was under the impression that they usually put longer ones in trucks.
400 SBC Casting Numbers Blue Squirrel Engine 8 12-16-2015 01:54 PM
pontiac 400 casting numbers any help? 409guy Engine 14 11-26-2009 03:34 AM
400 sbc hp numbers RedBush1 Engine 18 03-31-2009 03:35 PM
pontiac 400 id numbers RACER805 Engine 4 09-02-2008 07:08 PM
Turbo 400 numbers need decoding gator412 Transmission - Rearend 0 07-06-2007 01:56 PM
