T-400 overfill - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-11-2012, 11:48 PM
T-400 overfill
I still have not figured out my TH400 problem. I need to overfill the trans by 2 quarts to get it to shift right. If Im at the proper level it will shift soft and slow or not go into gear at all. I put in a new high flow brass filter figuring that was the problem- still no change. The only thing I can think of is that the pump is going bad.
When shifting all my other automatics (th350, & 4l60e) from park into drive or 1st, the car will lurch ahead. When my put my TH400 into 1st, it doesnt move at all- you wouldnt even know its in gear until you give it some gas. Idle is set at like 700 too. Could that be a sign of low pressure in trans?
Trans is built with reverse valve body and shift kit. Works fine when overfilled, but keeps blowing out rear seals.
1967 400 with 670 heads. Trying for 400 Hp street 67pontiac400 Engine 23 07-20-2012 08:45 AM
oil overfill ap0001 Engine 2 01-21-2012 04:57 PM
overfill oil bannasch Engine 2 07-17-2007 11:12 PM
What happens if you overfill your trans? JJ350 Transmission - Rearend 10 05-30-2007 10:30 AM
Overfill Damage k2mooch Transmission - Rearend 5 01-30-2004 10:38 AM
