T-400 problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-14-2012, 02:42 PM
T-400 problem
Hello, i have an problem with my TH400, i diassembly it full, and assemble it again with the same parts, i put it in the vehicule, put oil on it and run, the vehicule move good like 30seconds, and then al gears are like it was in neutral, so i popped out the cooler line and start it, and i observe that it spit some air, so i plug the oil line again, run the vehicule, and it do the same thing, 30sec and all gears neutral, it change gear very well, the level seems to be right, should i add more trans oil?, i have a deep pan, and i put like 10quarts of oil on it, there's a method to bleed the air?
pd:sorry for english im from Chile
Regards
Old 10-16-2012, 06:55 AM
SSedan64's Avatar
No need to bleed air from the Cooler lines.
With the Engine running fluid should be pumping out the Cooler line.
If the TC/TorqueConverter was not fully/completely installed into the Trans Pump it will break the Pump gear.
There should be 1/8" to 3/16" inch clearance between the Flexplate & TC before sliding the TC forward and bolting it up to Flexplate. If no clearance was present the TC was not fully/completely installed.
The fluid level is checked with the engine running.
Automatic Transmission & Torque Converter Fluid Capacity - TCIŽ Auto
The Following User Says Thank You to SSedan64 For This Useful Post:
TJ555 (10-16-2012)
Old 10-16-2012, 09:16 AM
I just put a th400 with deep pan in my truck. ive put 16 quarts in and its not full. You need more fluid IMO. I also have a external trans cooler, which adds capacity.
Old 10-16-2012, 11:40 AM
I have between 1/8 and 3/16" inch clearance, can i MAYBE install something backwards on valve body?, i will throw down the pan tomorrow :/
Old 10-16-2012, 01:10 PM
also, the pump flows like 1liter per 10seconds when i unplug the cooler line, so i think the pump is good
Old 10-17-2012, 04:11 AM
SSedan64's Avatar
The amount of flow is correct. So the Pump is working.
Spitting air, it may be low on fluid & allowing the filter to suck air.
With a Deep Pan it will require more fluid than a Stock Pan. May need 2 to 4 qts./ltrs. more.
TC & Trans fluid capacities >> Automatic Transmission & Torque Converter Fluid Capacity - TCIŽ Auto
Are you checking the Trans fluid level with the Engine running?
Do you have the Filter Extension that is used with a Deep Pan? It positions the Filter lower into the Pan.
Old 10-17-2012, 07:20 AM
i'm checking the level running, its a little more than full, i also puto the filter extension.
the trans was working and i diassembly it because the driveshaft broke and made a little hole in the case, i weld it and reassembly with the same parts.
Can i put something on the valvebody in the incorrect position?, now i will take off the pan to check for something there
Old 10-17-2012, 01:15 PM
sorry but 10 quarts doesent seem like its enough. not even for a stock pan.
Old 10-17-2012, 04:50 PM
10 quarts is about right if he didnt drain convertor
Old 10-17-2012, 06:53 PM
SSedan64's Avatar
It is possible something in the Valvebody isn't correct, Checkballs, Valves, Springs, Gaskets.
Also in the Pump, Pressure Regulator & Boost Valves, Gasket.
If you have a Pressure gauge you can test it to see what's going on.
0-200psi. gauge & hose will work. 1/8" NPT Port on left side of Trans.
1000rpm w/brakes applied:
Neutral = 55-70psi.
Drive = 60-90psi.
Drive-2 = 135-160psi.
Reverse = 95-150psi.
Drive @Idle = 60-85psi.
Drive 1000rpm w/Detent Solenoid On = 90-110psi.
Is the Modulator hooked up to Manifold vacuum?
TJ555 (10-17-2012)
Old 10-17-2012, 09:56 PM
Neutral = 55-70psi.
Drive = 60-90psi.
Ok, i took off pan and VB, and it was missing one spring (Picture)
So i took off one from another VB, tomorrow i will test it.
can the missing spring cause the problem?
Old 10-18-2012, 05:13 PM
Isn't that spring, the problem continues after put it, i dont know what else can be :/
transmission
turbo 400 problem astrovanman Transmission - Rearend 2 07-08-2012 12:39 PM
400 TH Problem? reflog Transmission - Rearend 6 07-16-2008 07:39 AM
turbo 400 problem JamesRS Transmission - Rearend 13 10-03-2004 04:27 PM
TH 400 shift problem BigBlock69 Transmission - Rearend 34 02-03-2004 11:43 PM
I think I may have a problem, (400/4BBL) ramjet Engine 2 03-09-2003 07:02 PM
