T-400 problems
I have been cruising the forums and can't find any help so I finally decided to join here as you guys have secretly helped me in the past. haha. I Have a TH400 tranny that i pulled from a running driving vehicle. I replaced the pump gasket and put a B&M shift kit in it. It then sat for a few months. I put it in a buddys pickup that he tore up his 350 trans. So we put the 400 in with a new B&M converter. We filled the converter with fluid and filled the trans up. My problem is I don't have any gears at all. Just park. We put the truck on stands and the tires barely move when in gear. Not even enough to budge the truck when its back on the ground. Any ideas? I m figuring that it has something to do with the valve body. Any help would be great. Thanks guys
