-   -   T-400 question (http://www.hotrodders.com/forum/t-400-question-215676.html)
bbowerman 02-29-2012 07:10 AM
T-400 question
I am swapping my 76 silverado's th350 with a th400 because the th350 is blown I am going to need a yoke but Im not sure where to get it there are some on ebay I was wondering if someone could guide me too finding this. All help appreciated.
junior stocker 02-29-2012 12:43 PM
I got tired of replacing the TH350 transmissions in my 82 Silverado, and decided after the last TH350 went, it was time for a TH400. Best move I have ever made! Solid shifts, no lag, and I don't thyink I'll wear it out like the TH350's. Now, the "short" length TH400 is actually shorter than the 9" extension housing TH350 transmissions used in most trucks. I did'nt want to swap driveshafts, or have one made; so, I got a "longer" slip yoke to make up for the driveshaft being just a bit short. This yoke can be cut down as needed, but I did'nt do this. I should have as it bottomed out on the speedometer gear in the trans and shifted it's placement. I don't have a speedometer that currently works due to that, but when the weather finally gets decent again I'll shorten the yoke and reset the speedometer gear. I don't remember the part number for the slip yoke; I got it off of E-Bay. One of it's applications was for use with a transfer case, that may help your search.
seven1nova 02-29-2012 02:26 PM
you can try here
http://www.dennysdriveshaft.com/index.html
bbowerman 02-29-2012 10:26 PM
thanks for the advice and info will check it out
bbowerman 02-29-2012 10:27 PM
y'all dont happen to know what u joint my 76 half ton would have stock do ya?
bbowerman 02-29-2012 10:29 PM
also is this: http://www.dennysdriveshaft.com/p102...turbo_400.html
long enough or do I need to find a longer one?
bbowerman 02-29-2012 10:34 PM
or this http://www.dennysdriveshaft.com/p129...ng_barrel.html
bbowerman 02-29-2012 10:52 PM
Im gonna finish pulling out the TH350 tommorow so I need one pretty soon I think the TH400 will bolt right in if not I got a Dewalt and some drill bits lol
bbowerman 02-29-2012 11:05 PM
Also just an opinion it has a cam and is bored over .030 would you go with a stall or not I'm gonna say no because the cam is only slightly bigger than an rv cam. just wondering what your opinion on stall converters are. :thumbup:
rick 427 03-01-2012 08:13 AM
If you have a dual converter bolt pattern flexplate,you can substitute the 13'' 400 converter with a 350 12''....that'll give you a few hundred rpm's of stall over the 400 converter.
bbowerman 03-02-2012 06:50 AM
is it very possible that my torque converter clutches are bad
oh and rick I was checking out your journal :thumbup: for the 32 ford with chevy engine.
