T-400 question - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-29-2012, 06:10 AM
Last journal entry: 76
T-400 question
I am swapping my 76 silverado's th350 with a th400 because the th350 is blown I am going to need a yoke but Im not sure where to get it there are some on ebay I was wondering if someone could guide me too finding this. All help appreciated.
Old 02-29-2012, 11:43 AM
junior stocker's Avatar
I got tired of replacing the TH350 transmissions in my 82 Silverado, and decided after the last TH350 went, it was time for a TH400. Best move I have ever made! Solid shifts, no lag, and I don't thyink I'll wear it out like the TH350's. Now, the "short" length TH400 is actually shorter than the 9" extension housing TH350 transmissions used in most trucks. I did'nt want to swap driveshafts, or have one made; so, I got a "longer" slip yoke to make up for the driveshaft being just a bit short. This yoke can be cut down as needed, but I did'nt do this. I should have as it bottomed out on the speedometer gear in the trans and shifted it's placement. I don't have a speedometer that currently works due to that, but when the weather finally gets decent again I'll shorten the yoke and reset the speedometer gear. I don't remember the part number for the slip yoke; I got it off of E-Bay. One of it's applications was for use with a transfer case, that may help your search.
Old 02-29-2012, 01:26 PM
seven1nova's Avatar
you can try here
http://www.dennysdriveshaft.com/index.html
Old 02-29-2012, 09:26 PM
thanks for the advice and info will check it out
Old 02-29-2012, 09:27 PM
y'all dont happen to know what u joint my 76 half ton would have stock do ya?
Old 02-29-2012, 09:29 PM
also is this: http://www.dennysdriveshaft.com/p102...turbo_400.html
long enough or do I need to find a longer one?
Old 02-29-2012, 09:34 PM
or this http://www.dennysdriveshaft.com/p129...ng_barrel.html
Old 02-29-2012, 09:52 PM
Im gonna finish pulling out the TH350 tommorow so I need one pretty soon I think the TH400 will bolt right in if not I got a Dewalt and some drill bits lol
Old 02-29-2012, 10:05 PM
Also just an opinion it has a cam and is bored over .030 would you go with a stall or not I'm gonna say no because the cam is only slightly bigger than an rv cam. just wondering what your opinion on stall converters are.
Old 03-01-2012, 07:13 AM
rick 427's Avatar
Last journal entry: The Cheetah
If you have a dual converter bolt pattern flexplate,you can substitute the 13'' 400 converter with a 350 12''....that'll give you a few hundred rpm's of stall over the 400 converter.
Old 03-02-2012, 05:50 AM
is it very possible that my torque converter clutches are bad
oh and rick I was checking out your journal for the 32 ford with chevy engine.
Th 400 question Icelander Transmission - Rearend 3 09-08-2009 05:56 AM
400 question 66 chevy truck Engine 3 10-23-2006 08:04 PM
400 sbc question 4doorjoe Engine 4 10-11-2005 12:50 AM
400 SB question Milecki Engine 2 12-27-2002 07:31 PM
400 SBC Question MI2600 Engine 4 12-02-2002 08:04 PM
