t-400 rebuild confusion - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-02-2010, 11:41 AM
soBit's Avatar
Getting older by the Mile.
I found this forum looking for information with the TH 400 I am rebuilding. I have 2 manuals and a video on rebuilding but they conflict on specs and the models they list have 3 character deignation all starting with A, mine is model FI. Manual model says all other models, which I assume mine is, should have a dished plate in the forward clutch, it does'nt.
Anybody know where I can get information on specs and MODEL numbers.
Thanks.
Old 04-02-2010, 02:00 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Welcome to the site, If you post your question in the transmission section i am sure Crosley will come along and help you out, He is a transmission Guru
Cole
Old 04-02-2010, 10:44 PM
Crosley's Avatar
Wiki Edits: 1659
Thanks.
These t-400 trans are many years old.. the inner workings may have been modified or replaced.
If you have an aluminum piston design for the dished shaped cushion plate.. it is advisable to toss the dished plate ( they crack - break) , install a flat plate on top of the aluminum piston , then a waved cushion plate if working on the forward clutch drum.
A direct drum , I remove the cushion plates completely
rebuild parts for a 400 Overdriv Transmission - Rearend 6 02-02-2010 09:57 PM
THM 400 rebuild question sllayer1 Transmission - Rearend 4 01-11-2010 10:28 AM
Turbo 400 rebuild skiscott00 Transmission - Rearend 1 11-25-2006 10:49 PM
pontiac 400 rebuild 409guy Engine 2 04-06-2004 05:22 AM
400 trans rebuild? DeathByGreaser Transmission - Rearend 3 11-27-2002 01:54 PM
