T-400 reverse manual valve body problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-18-2010, 12:12 PM
Hi everyone,
I have a TH400 on the bench that's been recently "built", and has a reverse pattern manual valve body w/brake. I have no idea who built the trans or where the valve body came from. All I know is, it shifts really sluggishly and softly. I would expect it to give you whiplash when shifting and to shift as soon as you told it to, but it doesn't. Governor has been completely removed, all check balls are gone, front band servo piston is gone, and there's no 2-3 accumulator, even though the passage isn't blocked.
This is my first TH400, but not my first trans. Any ideas as to what's causing the slow/soft shifting?
Old 02-18-2010, 07:00 PM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
Originally Posted by huafist
Hi everyone,
I believe there should be one check ball still there. It should go in the "bathtub". I have a picture of it on my computer at home but thats 650 miles away.
Old 02-18-2010, 07:30 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
The reverse pattern v-body I deal with do not need check balls anywhere in the application.
Have you tested the line pressure? If pressure is low , this will cause poor shifts
Old 02-18-2010, 08:12 PM
No, the trans is on my bench. I've got the VB out of it right now. I have no idea who did the valve body, it has stock GM body casting numbers on it. I'm wondering if it's truly a reverse pattern, or just a homebrew full manual.
The seperator plate has a 4 digit number stamped in it, but I don't remember right off hand what it is. Shouldn't the front band servo piston still be in the trans for the brake, and shouldn't there be a set screw in the case to block off fluid flow to where the 2-3 accumulator used to be?
If the line pressure was low, wouldn't it slip as well? I was told it does not slip at all. Just slow to shift and does so softly.
Old 02-18-2010, 08:15 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
No, the trans is on my bench. I've got the VB out of it right now. I have no idea who did the valve body, it looks like GM stock body. I'm wondering if it's truly a reverse pattern, or just a full manual.
soft shifts are slipping shifts usually.
the band servo is unneeded
the 2-3 accumilator is unneeded. If you look at the separator plate , it probably blocks off many of the areas you worry about.
4 digit number.. would that be 2211R ? Or 2215
Often a OEM valve body is machined into a different configuration as a reverse pattern or trans brake v-body, very common process
Old 02-18-2010, 08:44 PM
2215, I believe.
Now that I think about it, I believe you are correct. the plate does block those off. Should the holes for the governor oiling tubes be blocked off?
Perhaps the pressure regulator spring in the pump is weak?
Old 02-18-2010, 10:06 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
usually the 2215 number indicates a trans brake valve body, could be several different brands. These are also reverse shift pattern.
Is the separator plate natural aluminum or red in colour ?
the trans would require a tear down by an experienced high performance tech.. I can guess till next year on what the problem is with your trans with out seeing it
Old 02-19-2010, 06:35 AM
It's neither aluminum color nor red ; it resembles the coating on a lot of grade 8 bolts - that goldish-orange color.
Old 02-20-2010, 09:58 PM
No problems to be found in the valve body. Pulling the pump tomorrow to check the line pressure spring, gonna pull the drums to check the clutches as well. There was an awful lot of clutch material in the pan when I pulled it off.
Old 02-20-2010, 10:31 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
It is posible yellow zinc coating on the plate.
If you pull the pump, I would be checking the pump gear clearance
Old 02-21-2010, 09:06 AM
Will do. I'll post the results later today. Thanks for the help, Crosley. I really appreciate it.
Old 02-25-2010, 07:40 AM
Sorry that it's taken me this long to get back to this. I pulled the pump apart last night, and there's scoring on both sides of the pump case where the gears have been chewing into it. The clearance comes out ok at .003", but all the components are worn pretty badly, so when it's put together I'm sure it's out of spec. The bushing looks rough as well. My big concern is, if the clearance is ok, what caused the damage? A misaligned converter possibly?
Name:	trans pump2.jpg
I lose compression w/ valve adjust drivehard Engine 5 11-23-2009 10:29 AM
700r4 valve body problems lilnach Transmission - Rearend 6 07-21-2009 10:05 PM
master cylinder interchange runn141 Suspension - Brakes - Steering 7 05-03-2009 06:15 AM
700R4 Why are the TCI manual valve body instructions so lousy? Bayley Transmission - Rearend 24 02-16-2009 01:49 PM
Turbo 400 Manual valve body Tbucit Transmission - Rearend 3 05-10-2006 10:30 PM
