T-400 shift problems after Superior brand valve body kit install
Hey guys, I installed a Superior shift kit yesterday and now it will not manually shift to 2nd. The only thing that I didnt do was change the spring in the pressure regulator. I dint have a set of snap ring pliers that would fit in the snap ring and I was trying to get it ready for the track. If you put it in drive, it shifts fine. With the kit I had the option to change the governor springs but didnt mess with it cause I am only racing this car. Any advice? I hate to drop the pan again, but guess thats about all I can do.
Not sure, its actually a 3l80 HD with 6 check balls. The kit is supposed to work with all TH400's 3l80's with 6 or 7 check balls. It is very possible that one of the balls fell out as I was putting in the separator plate. I am going to drop the pan this weekend and check it out. Im going to install a drain kit in it this time so I can save the oil if I have to go through this again.
| T-350 7 400 valve body problems? | bigiron40 | Transmission - Rearend | 2 | 05-10-2008 07:23 AM |
| Valve body kit, shift kit, servo kit-What's the difference? | coda618 | Transmission - Rearend | 2 | 05-07-2008 01:48 PM |
| Shift kit or manual valve body??? | OneMoreTime | Transmission - Rearend | 6 | 03-08-2008 03:19 PM |
| Modifying th350 valve body at home - Custom shift kit? | Warrant | Transmission - Rearend | 5 | 11-24-2006 07:39 AM |
| auto shift kit in manual valve body? | cadillacart | Transmission - Rearend | 0 | 01-11-2004 09:03 PM |
