T-400 shift up problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-08-2009, 01:46 PM
Hey there!
Finally my friend got his 'Camino on its wheels few months ago - now 350SBC with Weiand blower instead of 400SBC. Some long time messing with wrong carbs, all other problems and finally, we got stuck with TH700.
Near the carb there was the TH700 TV cable that my friend used to adjust revs at which the gearbox will shift up. Until the shift up rev was set to ~ 3000 rpm which is about 75 mph on second - that's not a good idea for city driving. And the TV cable didn't want to change the shift up rev any lower.
What can it be? The mechanic that assembled the engine took the gearbox off already, but he didn't say anything special about the problem (some "water words" - as he must say something when a customer comes to visit his long awaited car).
Please, tell me where the problem can hide.
Thank you!
Wow! Guess some one has the same prob.
Old 09-09-2009, 07:51 PM
SSedan64's Avatar
Originally Posted by Diskovod
Hey there!
Thank you!
If the TV cable is too tight it can cause very high rpm shifts or no shift at all. The TV cable should not be used to set the rpm's the trans shifts at.
"The TV cable used on the 4L60/THM700-R4 and TH200-4R controls line pressure, shift points, shift feel, part throttle downshifts and the detent downshifts."
The Governor controls WOT/WideOpenThrottle shift points and Part throttle shift points combined with the TV/ThrottleValve.
You can get Governor Recalibration Kits to increase or decrease the rpms the Trans shifts at. >> http://www.summitracing.com/parts/TCI-326500/
TV 101 Article, 3 parts. >> http://www.tvmadeez.com/article/index.php
Adjusting TV cable. >> http://purplesagetradingpost.com/sum...o/700R4p1.html >> http://www.tciauto.com/Products/Inst...ble_adjust.htm
Old 09-10-2009, 01:15 AM
Thanks! But we had a problem, after it started shifting from 3000 rpm TV cable couldn't be adjusted anymore. Probably the connection might have felt off (I didn't notice actually, it's my friend's car, not mine) but could something fail?
T-400 won't shift cornfieldcars Transmission - Rearend 5 07-09-2009 04:51 AM
T-400 shift kit ? 1970 gp Transmission - Rearend 11 05-19-2009 06:44 PM
400 w/brake shift problem hotrod Transmission - Rearend 4 06-23-2005 12:14 AM
TH 400 shift problem BigBlock69 Transmission - Rearend 34 02-03-2004 11:43 PM
400 th shift kit help gpeak Transmission - Rearend 2 01-07-2004 04:51 PM
