-   -   T-400 Shifting problems (http://www.hotrodders.com/forum/t-400-shifting-problems-200043.html)
Flhxrider 06-08-2011 06:55 PM
I have a TH400 automatic trans that had no reverse or third gear left in it. I rebuilt the transmission, air tested the clutches after assembling the clutches and the work good. I did a complete rebuild(bushings, seals, seal rings, thrust washers) and instaled a shift kit. My problem is it does not shift into 3rd gear on acceleration and does not down shift to first after coming to a stop, and no kick down to passing gear. I am thinking possibly a governor, but looking for help.
bbuss 06-09-2011 06:02 AM
400
sounds like governor sticking.
