Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - T-400 shifting too quick
  #21 (permalink)
Old 12-21-2012, 07:35 AM
496CHEVY3100's Avatar
496CHEVY3100 496CHEVY3100 is offline
Built Not Bought
Last journal entry: 53 ad3100
You can drill and tap a port at rear for vacumn connection ,be shure you have Heavy grease on drill bit to catch alumimum shavings ,i would also remove carb and duct tape on inside where you will be drilling. or you can buy an aluminum spacer plate to go under carb with vucumn port already in it ,I have one but do not know how to put pictures on this sight ,if you cant find one i will posy picture in my picture albumn Also do you have the elactric kick down connected if not it will shift to early part throttle or WOT
