T-400 shifting too quick - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-11-2012, 08:07 PM
sscanrun's Avatar
I have a big block and I just got a th400 built and have a 2600-2800 stall, gear 3:90 and a single plane intake. Its a street/strip car but the car see more of the street than the track
Old 12-11-2012, 08:09 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Mounts
Vacuum modulator connected to MANIFOLD vacuum?
The Following User Says Thank You to 66GMC For This Useful Post:
sscanrun (12-11-2012)
Old 12-11-2012, 08:15 PM
sscanrun's Avatar
66GMC - the carb
Old 12-11-2012, 08:28 PM
SSedan64's Avatar
Some Modulators are adjustable, small screw inside tube where Hose connects. It will give a small 3-5mph range.
For more adjustment you'll need a Governor Recalibration Kit.
B&M Governor Recalibration Kits 20248 - SummitRacing.com
Modulator needs Full Manifold Vac, not Ported/Timed Vac source.
The Following User Says Thank You to SSedan64 For This Useful Post:
Old 12-11-2012, 08:35 PM
66GMC's Avatar
Yup ... I'd start with connecting the vacuum line directly to MANIFOLD vacuum.
Old 12-11-2012, 08:46 PM
sscanrun's Avatar
Ssedan64 -will try
Old 12-11-2012, 08:50 PM
sscanrun's Avatar
I have to drill a hole on the single plane intake. That means I have to remove it?
Old 12-11-2012, 09:13 PM
stea's Avatar
I recently did the governor mod on my th 350. Im all smiles now. Regular part throttle shifts with full throttle 5500 rpm shifts. It actually gets in to an rpm range the cam likes.
Old 12-11-2012, 11:09 PM
Bye Jerks
Yup, you need the governor recalibration kit. Easy to do, but you basically have to guess the springs and weights, then test drive it.
Took me 4 tries to nail mine down.
The Following User Says Thank You to 632Mantis For This Useful Post:
sscanrun (12-12-2012)
Old 12-11-2012, 11:35 PM
stea's Avatar
I was lucky, got it first try. Used stock springs and IIRC I went 4 grams total lighter on the weights. The original weights that were on the governor were a lot lighter than i expected.
The Following User Says Thank You to stea For This Useful Post:
Old 12-12-2012, 07:52 AM
66GMC's Avatar
Really? There are NO provisions on that intake?
There is usually one on the rear face of the manifold, below the carb mounting flange. If not, that's where I would CAREFULLY drill and tap a 1/8" NPT hole for a small vacuum hose-barb.
You may be able to do this by simply removing the carb and taping off the intake runners to prevent any material getting away on you. Drill and tap the hole, and then vacuum up the debris.
Use extreme care when tightening any pipe thread fittings on an aluminum intake, as the the thread is tapered and can crack the intake if over-tightened.
Old 12-12-2012, 04:03 PM
sscanrun's Avatar
Its a single plane not the dual plane
Old 12-12-2012, 04:37 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Not necessarily. "Manifold" vacuum only means a full-time vacuum source that is there even at idle. "Ported" vacuum is NOT there at idle, and that's the main difference between the two (there are subtle differences besides that, but they do not apply here).
So you can use a carb port that has manifold vacuum just as easily as using a vacuum port that's in the intake manifold itself, if you follow me.
If you have a Holley, the metering block has a ported vacuum port- do not use that. You can use a port that's located on the baseplate, but still double check to see that it has full vacuum at idle.
An Edelbrock carb has a manifold vacuum port on the front, driver side.
The Following User Says Thank You to cobalt327 For This Useful Post:
Old 12-12-2012, 06:23 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I'm using the one on the metering block
That is the wrong place to get vacuum for the modulator. Use a full time port from the baseplate.
Old 12-12-2012, 07:37 PM
sscanrun's Avatar
Cobalt327- thanks ima try that tomorrow
turbo 400 not shifting truckboy61 Transmission - Rearend 13 09-14-2009 08:00 PM
400 shifting problem Jeff L88 Transmission - Rearend 7 10-10-2005 04:13 PM
TH-400 Shifting novatech Transmission - Rearend 1 07-31-2005 12:52 PM
Auto shifting to quick! chevelle327 Transmission - Rearend 6 11-25-2002 06:57 AM
Turbo 400 not shifting soon enough Mike Phillips Transmission - Rearend 2 10-09-2002 07:43 PM
