Originally Posted by Crosley
Send me a PM if you still need the OEM type valve body gaskets.
Well, here is the update. I ordered and installed (from the botttom side) the transgo reprogramming kit. To my huge disappointment, there is absolutely no difference, so the problem lies within. It seems that I am going to have to pull the unit out and rebuild it again. With the exception of looking for broken/damaged seals, do you have any particular suggestions?
Not sure if this helps, but when I test drove it in ratchet mode it remained in 1st to 6000 rpm and when I shifted up it simply stayed in 1st. When I shifted again in hit 3rd, but it never hits hard, it slides into gear like a granny car. I do have a 3500 stall converter and large tires, so will this thing ever bang the gears when it is right?
Thanks again for all of your help..
Steve
