Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - T-400 slips in drive but has reverse after rebuild
Old 04-28-2013, 07:59 PM
Crosley's Avatar
Crosley Crosley is offline
Global Moderator
Wiki Edits: 1659
Sounds like the T-400 forward clutch is a problem.
Was the T-400 parts replacement job performed with a full paper and rubber kit? Sealing rings in this T-400 were metal or a teflon looking material?
Clearances on the clutch pack of this T-400 were set at what clearance?
What condition was the pump in this T-400 ? Was the side clearances of the gears checked in this T-400?
