I always have the nose of the car way down and the rear up fairly high. The front wheels on the ground and GOOD jack stands under the rear end or the drive on ramps ... slid up under the rear wheels ( jack the vehicle up and slide the ramps under the wheels and lower the vehicle ) DO NOT try to drive up backwards on the ramps
Then the fluid is at the front of the case and you can remove the bullet ... and COUNT the number of teeth on the output shaft or check the color. The 40/45 housing is fairly unusual to find but they are out there. My Chevrolet dealer has both in stock ( or did a year ago ). The gears are color coded by GM I have found the 15 tooth to be either grey or brown The 17 is usually red. The driven gears are also color coded. 37 teeth - red 38 teeth - blue 39 teeth - brown 40 teeth - black 41 teeth - yellow 42 teeth - green 43 teeth - purple 44 teeth - dark gray 45 teeth - light blue So by determining the color of the driven gear You can actually determine which housing bullet you have by reading the end of the gear ( color ) where the speedometer cable goes. Some of the bullets even have the range size that they are ... in a small cast number on the face of the bullet. Deuce Moderator
"I won't be wronged . I won't be insulted, and I won't be laid a hand on. " |
Thats alot of good info, thank you. The transmission is in a 79 pickup. It had a 6 cylinder originally so now that it has a 454 in it the nose is sagging a bit so that will help get the fluid to the front. I can also jack up the back but it needs to be on stands because I think the wheels will have to turn (thus turning the transmission) so that I can count all the teeth on the gear (unless I can identify it by color which it sounds like I should be able to).
There are a several numbers on the bullet (which i am assuming is what I was calling the speedo housing) in the upper 30s so I am assuming its the small one. That means that i'll need to get a big one so I can use the 43 tooth driven gear. I'll try to get it apart today so I know 100% for sure everything that I need to know. Thanks again! |
| speedometer gear | hyde | Transmission - Rearend | 1 | 11-18-2012 08:28 PM |
| Turbo 400 trans speedometer gear? | Pro Street | Transmission - Rearend | 5 | 06-19-2006 05:42 AM |
| speedometer gear | Blob | Transmission - Rearend | 3 | 07-17-2005 04:22 PM |
| speedometer gear | 1986 Trans am | Transmission - Rearend | 2 | 10-26-2003 02:00 AM |
| How to get to the speedometer gear on a Turbo 400? | wreakhavoc | Transmission - Rearend | 1 | 10-30-2002 05:46 PM |
