T-400 speedometer gear question - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-26-2013, 10:05 PM
sqeezeit's Avatar
Are the speedo drive gears all the same physical size?I ask because I have a smaller tooth gear housing and the speedo gear doesnt even make contact with the drive gear on the output shaft?Someone told me that I might need the 40-45 tooth housing because it offsets the gear more to make contact?I am just wondering if its not something with the drive gear being wrong also.Any one have any ideas.I guess I hate to buy new housing and still not work.
Old 07-27-2013, 05:38 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
There are both large and small gear sets.
More here.
Old 07-27-2013, 07:32 AM
sqeezeit's Avatar
Thanks but not sure that helped,Ive seen that page and says nothing(unless I missed it) about different size drive gears(not tooth count).Iam wondering if something came loose on the install,because my drive gear on tail shaft is towards the engine to far,maybe it slid out of place on the shaft?
Old 07-27-2013, 08:03 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
The T-400 speed-O housings are divided into 36-39 and the 40-43 tooth designs.
The T-400 stem of the plastic gear is a different diameter for each housing tooth count design. You can not interchange the gears between housings. A 44 tooth gear will not fit a T-400 housing for 36-39 tooth gear or the other way around.
I suggest you verify the correct parts are on the T-400 output shaft, then verify the driven gear and housing. I had a fellow a few years ago , trying to install speed-O housing for a torque flight into a T-400.
Old 07-27-2013, 10:32 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The drive gear should be basically directly under the driven gear housing hole in the tail housing.
If you have a plastic drive gear, there's a spring steel clip that has one end secured in a hole in the tailshaft. The other end snaps the drive gear into place. There's a chance the drive gear was knocked out of position, or the wrong size clip was used instead of the correct clip.
Steel gears used on some early transmissions are a press fit and I seriously doubt you'd be able to move one out of position under ordinary circumstances, so if there's a steel gear and it's loose enough to be bumped out of position you need to replace it altogether.
Old 07-27-2013, 01:19 PM
Info Link for your speedo issues
Try this site for some additional info on T-400 driven and drive gear set ups
AOD, AOD Performance Transmissions from PATC, AOD Transmission, AOD Mustang, AOD
Old 07-27-2013, 01:23 PM
I think this site will get you to the speedometer side of there business
transmission center.org
Old 07-28-2013, 02:00 AM
Wiki Edits: 85
As noted by several before me, you cannot mix and match speedo gears and housings. The gears (40 & up) with larger tooth counts are larger in diameter than the smaller gears (39 & under) to accommodate the extra teeth. The larger diameter requires a different offset so the teeth make proper contact with the drive gear.
If your gear and housing match, then you have a different problem, possibly, as noted above, a missing or loose drive gear.
What is confusing to me here is that you say you have the smaller housing (39 & under I presume), yet your gear does not contact the other gear. If you had a mismatched housing and gear in this instance, you could not even insert the assembly into the transmission without using a bigger hammer and ruining the gear(s) in the process.
How about counting the teeth on the driven gear and posting the tooth count and the casting number(s) on your housing? There may be something else at play here that is not obvious without more info.
Old 07-28-2013, 02:42 AM
sqeezeit's Avatar
Yes this is exactly what Iam trying to do, what u last said in message
Old 07-28-2013, 02:50 AM
sqeezeit's Avatar
I never did count drive gear teeth yet,and I think it was yellow in color,not sure.I do have the right housing and driven gear,it is a 36-39 housing.I know the 40 and up are bigger diameter of driven gear so wont fit my housing(tried it before I knew this).Will get back with more info,but just wondering if the drive gears are different diameters also?Could it not have the right drive gear,from what I read theres a few different tooth count drive gears but I guess didnt or wouldnt think it wouldnt even touch the speedo/driven gear if it was wrong,I dont know.
Old 07-28-2013, 12:15 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Photos of T-400 output shafts. I have these parts on hand. I dont need to search the web for photo stuff that may be correct or not. .. hope this helps
T-400 both shafts:
T-400 metal gear:
T-400 Plastic gear with clip:
Old 07-28-2013, 09:29 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Old 07-29-2013, 06:56 AM
Tooth Count and Housings
Not sure if you got the answers your looking for yet. The drive gears on your Output shaft can be either 14 or 15 tooth counts. The plastic one is a 15 tooth gear, the metal one looks a lot smaller and could be incorrect. You will need to trace one tooth on the gear from beginning to end, then count the remaining teeth to determine the count. 400 driven gear housings will work with any drive gear, they range from 34-39 and 40-45. To determine what you need go to transmission center.org to use their speedometer gear calculator.
Old 07-29-2013, 07:57 AM
sqeezeit's Avatar
Thanks for everyone's input very much apreciate it I know I have smaller housing with the right size smaller tooth count driven gear just don't know why it doesn't make contact with the drive gear on tail shaft? When I get home in a couple days will look a little closer and update status. Thanks again
Old 07-31-2013, 02:27 PM
sqeezeit's Avatar
Ok guys, update on issue.i found out I'm my own worse enemy of stupidity!after further looking it seems there is no speedo gear on the tail shaft.lol
speedometer gear hyde Transmission - Rearend 1 11-18-2012 09:28 PM
T-400 Speedometer gear changes Torque454 Transmission - Rearend 2 08-09-2010 12:45 PM
T-400 3rd gear question?? ss396si Transmission - Rearend 13 09-22-2009 03:36 PM
Turbo 400 trans speedometer gear? Pro Street Transmission - Rearend 5 06-19-2006 06:42 AM
How to get to the speedometer gear on a Turbo 400? wreakhavoc Transmission - Rearend 1 10-30-2002 06:46 PM
