What rear gears and tire size? 9.5 cr is a lot for a blown motor, be sure to limit your boost if you'd like to keep it together.
That said, I'm using a 2800-3200 and it's stalling about 3000, T-400, 4:11 with 31" tires. Talk to a rep.
Midnight Sun Street Rod Association |
i dont know what gears are in it. i just got the truck and haven't really started working on it yet. yah i know 9.5 cr is a bit high but when i started building the motor i dint think i would be pouting a 671 on it, but then one poped up for sale really cheap and next thin i know theres a blower sitting on top of my motor. what do you mean "be sure to limit your boost" i dont know all that much about blowers. but hay gota start somewhere
You can't just throw parts at a motor and expect it to be right or to live. You need to learn, read, talk to people. I'll assume that's why you're here.
Consider this, if you bought a Weiand 6 -71 off the shelf for your big block, they come set up to produce between 10 and 12 #'s of boost. With a static cr of 9.5:1, at 12 pounds of boost your effective cr will be right at 17.3:1. How do you think head gaskets will live with that kind of pressure? You know boost is adjustable simply by changing upper and lower pulleys? If you run that much boost and static cr, you will definitely need a boost retard system to pull some timing out, and something more than pump gas to handle detonation. Get your hands on a copy of Guide to Street Supercharging by SA Designs (SA-17). Here's a link to Weiand's tech pages as well, look at the pulley charts so see what kind of boost yours is set up for. http://holley.com/TechService/Library.asp Supercharger tech is at the bottom, it's a good place to start.
TH400 converter
Look into American Performance Engineering. They have done several converters for myself and many of my friends with no complaints. Got the stall speed right where we needed it
Good people to talk with, seem very competent.
TH400 stall converter
(765) 860-8701
(765) 437-0185 |
| what stall is this torque converter? | chevyrally68 | Transmission - Rearend | 1 | 05-02-2012 01:25 PM |
| Stall Vs 400 torque converter | mahoho | Transmission - Rearend | 5 | 09-14-2009 06:51 PM |
| Do I need a stall torque converter?? | 75GMCman | Transmission - Rearend | 4 | 05-11-2009 07:37 PM |
| B&M Torkmaster 2400 rpm stall converter vs. stock torque converter??? | zbhover | Transmission - Rearend | 2 | 11-02-2008 07:52 PM |
| stall torque converter | beetle9 | Transmission - Rearend | 11 | 12-28-2002 04:34 PM |
