T-400 Steel Speedo Gear removal?
I have a TH400 in my car.. not sure what it came out of but its a BOP trans. Speedo is way off.. so started to look into it. The drive gear in the case is a steel gear so it must be pressed on because i can not find the clip like in my other trans. I counted teeth and its a 21 tooth, which is way to much for my needs I have a 3.73 rear and 26.6" tire. What is the best way to remove the pressed on speedo drive gear. and when i get a new one like a 15 tooth do i need to press it on or if i get a plastic one can I use the clips or is the outputshaft different.
Any help is appreciated thanks jarrod |
its like 30+ miles over what it reads.. the steel gear is a 21 tooth, i have 3.73 26.6 inch tires.. the online calculators say i need a 59 tooth, which is not made...
reads 30 over what i am going driven gear is a 36 tooth I changed the trans out from my stock one a year or so ago. and been waiting till i did the rear end up grade to fix it.. and thats when i found out it was a steel gear... and the 30 or so over was with a 3.08 and 24 inch tire.. will be off a bit now i would expect with new gear and tire diameter
Crosley or Jakeshoe (members here), any help for finding the steel drive gears?
You could get most of it by going to a 45 tooth outer gear and matching housing(there are two for the TH-400, straight-thru and offset) and one of the add-on reduction boxes like 3/4, 1 ton, and heavy trucks used. Just an idea if you can't find a gear. Last edited by ericnova72; 07-18-2009 at 05:48 PM. |
I have new 15 tooth drive gears (steel).
I should have everything to get the speedo correct. I would have to check my driven gears and what you have. You'll need the 15 tooth drive gear though. Easiest way to get it off is to cut it with a cut off wheel almost through, hit it with a chisel to split it, and slide it off. There is a special puller to remove them, you could make something similar with a bearing splitter and some long all-thread but I would cut that one off. It's worthless
ya cutting it off would be easy.. kinda like how i did the axle bearings and retainers.. but how hard are they to press back on the shaft with the trans in the car still????
ok thank you. any locations where i can purchase those three things?
thanks.. sent email
| ford c-4 speedo drive gear | bigblk1177 | Transmission - Rearend | 2 | 02-24-2009 06:41 AM |
| Speedo gear red and brown? | redlightning | Transmission - Rearend | 2 | 09-26-2007 10:29 AM |
| Top loader speedo gear selection | pooshooter | Transmission - Rearend | 1 | 08-22-2006 04:49 PM |
| Distributor gear - iron or steel ? | markn | Engine | 0 | 05-29-2004 10:54 AM |
| TH-400 Speedo Drive Gear Replacement | 454impala69 | Transmission - Rearend | 6 | 03-17-2002 03:03 AM |
