T-400 tag decode? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-31-2010, 02:50 PM
Fang16's Avatar
Last journal entry: Project change
T-400 tag decode?
I've got a th400 with a tag on the right side that reads LM 9213A and below that is 90-LMA-1152. What do these decode as? I've looked for a VIN on the case but can't find one. One of the reasons I need to know is in hooking up an electronic speedo to it. It has the two wires from the ele speedo coming out of the tail shaft and of course the 1 prong kickdown switch farther up the case on the drivers side.
Thx!
Old 04-01-2010, 03:07 AM
Wiki Edits: 85
Thx!
All this will tell you is that it is a 1990 vintage TH400 unless you can find someone that has seen a vehicle that this code was in. I have never seen a code list for TH400s in the 30 years I have sold transmission parts. I am sure that somewhere in GMs archives there is something showing code listings, but I doubt if it was ever released for general use.
I see no reason why you need this information to hook up an electric speedo. Speedometer calibrations are always outside of the transmission and only vary because of rear end ratio, tire size, and driveshaft speed (usually the same as transmission output shaft speed). Output shaft speed is sensed either through magnetic pickup using a reluctor or through manual pickup using speedometer gears.
Most TH400s had VINs on them. Later TH400 VINs are hard to find since most were laser engraved in varying locations. Early VINs were always stamped on a pad just above the pan rail on the driver's side.
Old 04-01-2010, 06:36 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Thx!
I am not sure why you need to decode the trans for the electronic speed-O ?
There were only two types of electronic speed -O on the trans .. The gear driven style unit and the sensor style that reads the reluctor wheel on the out put shaft.
the gear driven style used the plastic speed-O gears like the cable speed-O
The reluctor wheel design was more common and the later design
Old 04-01-2010, 09:00 AM
Fang16's Avatar
Thanks guys!
I understand this tranny and what I'm doing a lot better now after your answers. My main concern was the speedo thing as I'm planing on using an auto meter electric speedo. I guess I have a later model th400 as there is no pad above the pan and it appears to have the later model ele speedo pickup.
Thanks again!
Can someone tell me how to decode this T-400 tag? adam83 Transmission - Rearend 8 02-16-2013 12:51 AM
Where to decode this trim tag? K and K Hotrodding Basics 0 08-09-2010 10:44 PM
Trim tag decode miller350ss Body - Exterior 1 10-10-2008 12:42 PM
decode rear end tag ford 9inch cswinc1028 Transmission - Rearend 1 05-13-2008 07:02 PM
Ford Rear tag decode 87442lover Transmission - Rearend 1 05-14-2004 10:15 AM
