I think Chris at CKPerformance was talking about doing Lockup TH400's on the TurboBuick.com Forum. It's been a while can't remember what ever happened. These would be Custom as none came factory w/Lockup.
Ok thanks, i figured that but i had my hopes kinda high in consideration of gas mileage.. Has anyone ever swapped a thm400 for a 700r4? including the display on the dash for p,r,n,d... i wonder if that would be very hard to do?
A lock up converter is only going to net a couple hundred rpm's, not enough to make any real difference in mileage especially considering the cost vs mpg gain.
A 700r4 could be swapped but depending on the application you may be giving up a stronger trans. Depending on the vehicle there are some companies that make replacement shift indicator displays. |
That is true, i know that the 400 is the toughest one available for a 1986 truck. I bought a new torque converter seal which was my main problem, just a small trans fluid leak, and a new torque converter as well just in case the old one was slipping and causing bad gas mileage.
Hi,
Yes. There is a "switch pitch" converter that came in TH-400s in Buicks, etc. in the 1970s. Likely hard to find. Good luck, Matt
| Torque Converter to Flexplate Torque Spec. Needed - 2004R | Zeeb | Transmission - Rearend | 1 | 05-26-2010 06:47 AM |
| B&M Torkmaster 2400 rpm stall converter vs. stock torque converter??? | zbhover | Transmission - Rearend | 2 | 11-02-2008 07:52 PM |
| torque converter install questions | dawg | Transmission - Rearend | 5 | 03-21-2008 05:13 PM |
| Torque Converter Transmission match up questions | MissJohnDeereGreen | Transmission - Rearend | 1 | 05-22-2007 10:08 PM |
| Headers & torque converter Questions | Mustangsaly | Engine | 19 | 09-27-2006 07:39 PM |
