T-400 tranny
What's the difference between a th400 and thm400 valve body's? And if there is any, would it take the same rebuilt kit? Thanks
th and thm stand for turbo hydromatic not many changes threw the yrs
64 was single range 65-66 had a varible stall speed converter then in 87 they added a extra check ball but for the most part there the same from 67-87 some shift firmess calibration was diffrent from vehicals 87 -90 had a difrent valve body and seperator plate |
So, can the th400 and thm400, use the same valve body kit? As a regular th400. Thanks
what kit are u looking at band m goes from 87 back i think trans go is for all yrs
TCI GM TH400 REVERSE SHIFT PATTERN FULL MANUAL VALVE BODY with Engine Braking
any thing from 67 to 87 will keep u on the safe side
| All times are GMT -6. The time now is 08:41 AM. |
