T-400 tranny - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-29-2012, 10:24 PM
T-400 tranny
What's the difference between a th400 and thm400 valve body's? And if there is any, would it take the same rebuilt kit? Thanks
Old 04-29-2012, 10:43 PM
joshp83's Avatar
owner of Prices Garage
th and thm stand for turbo hydromatic not many changes threw the yrs
64 was single range 65-66 had a varible stall speed converter
then in 87 they added a extra check ball but for the most part there the same from 67-87 some shift firmess calibration was diffrent from vehicals
87 -90 had a difrent valve body and seperator plate
Old 04-30-2012, 10:08 PM
So, can the th400 and thm400, use the same valve body kit? As a regular th400. Thanks
Old 04-30-2012, 11:09 PM
joshp83's Avatar
what kit are u looking at band m goes from 87 back i think trans go is for all yrs
Old 05-02-2012, 12:50 AM
TCI GM TH400 REVERSE SHIFT PATTERN FULL MANUAL VALVE BODY with Engine Braking
Old 05-04-2012, 02:31 AM
joshp83's Avatar
any thing from 67 to 87 will keep u on the safe side
T-400 tranny slip strokin Transmission - Rearend 1 09-23-2011 04:44 PM
upgrading from a 350 tranny to 400 angel85lx Transmission - Rearend 2 09-01-2011 08:55 PM
700 r4 88 gmc tranny- 400 turbo 87 gmc tranny ? limp'n-gmc Transmission - Rearend 6 02-15-2011 07:58 PM
400 tranny slipping 49dream Transmission - Rearend 5 05-02-2005 06:58 PM
tranny 350 or 400 heavychevy70 Engine 7 03-17-2005 04:28 PM
