T-400 tranny - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-19-2013, 12:58 PM
sqeezeit's Avatar
T-400 tranny
Ok fellows,I have never been in a 400 tranny and has been a long time since I ever serviced one so Im sorry if this sounds dumb.I bought the car last year and now servicing tranny. Im just wondering on the filter.Is the bolt that holds it on normally look like and is there any washers ect.When I took it off they had 2 orings on the tube to case and the filter was just kinda dangeling there and hanging low in back.By looking at when I put together with one oring(new filter/oring) just seems to hang low and wants to walk its way off the pickup tube.So Im guessing they doubled up the orings to bring down farther to make up for this.Is the mounting bolt suppose to hold the filter tight without movement(I would think so or close to it) now it moves a pretty good amount up and down,so just wonder whats normal or what needs to be there?Washers/wrong bolt?Thanks guys
Old 05-19-2013, 01:17 PM
The mounting bolt holds the filter loosely and yes, it does walk around with the bolt tightened. This is normal.
Old 05-19-2013, 02:07 PM
Wiki Edits: 85
Joe is correct, however do you have a deep pan or a shallow pan? If you have a deep pan, there should be a spacer sleeve on the bolt. The shallow pan does not use a space sleeve.
Old 05-20-2013, 01:26 AM
sqeezeit's Avatar
It's a shallow? Don't know the difference of the two but mine is about 1 1/2 inch deep or so. So the pan must keep filter on? I only ask because if I hold filter level(holding up on filter off of the bolt head) then if I wiggle it I can get the filter to fall off of tube. I guess I never measured yet so I should 2moro. My bolt has a 3/4" step in it. Does this sound like the right one for it. Thanks again for replies
Old 05-20-2013, 04:29 AM
Wiki Edits: 85
The deep pan is 2-7/8" deep, so you have the shallow pan.
The shallow pan bolt has a shank that is 23/64" long and 25/64" in diameter and has 5/16" threads that are about 11/16" long.
T-400 tranny fordss Transmission - Rearend 5 05-04-2012 02:31 AM
700 r4 88 gmc tranny- 400 turbo 87 gmc tranny ? limp'n-gmc Transmission - Rearend 6 02-15-2011 07:58 PM
T-400 tranny swap 1964_442 Transmission - Rearend 5 09-15-2009 09:49 PM
400 tranny slipping 49dream Transmission - Rearend 5 05-02-2005 06:58 PM
tranny 350 or 400 heavychevy70 Engine 7 03-17-2005 04:28 PM
