T-400 tranny slip - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-23-2011, 05:43 PM
T-400 tranny slip
Hey guys, bought a 87 Monte SS, did a bunch of work installed my 383 etc, it came with b&m turbo 400, I don't have much history on it other than guy said his buddy rebuilt it with all the best. From first to second it has a real slow, shift, worst when its cold, probably delays a second before shifting an even then it's not crisp 2nd to 3 rd is normal, im going to pull the pan to change filter and such, is there something I can look for in the shift kit that could cause this?
Old 09-23-2011, 05:44 PM
And yes the vacuum is hooked up ad yes it is adjustable, ty
94 chevy s10 zr2 tranny slip 94chevys10_zr2 Transmission - Rearend 3 07-01-2009 10:27 PM
Tranny fluid leaking THRU the slip joint??? murrsue Transmission - Rearend 22 02-21-2007 12:34 AM
2000 GrandAm tranny slip? ChevelleSS_LS6 Transmission - Rearend 11 07-15-2006 11:43 PM
why does my tranny slip when i turn right? biscotrain Transmission - Rearend 6 07-30-2004 12:13 PM
anti slip or no slip Terry411 Transmission - Rearend 2 05-01-2003 05:05 AM
