T-400 trans question - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-11-2011, 06:29 AM
I have a th400 in a 1969 firebird, 3.55 rear, 25" tire. tach shows 3500rpm at 55mph. calculator says I should be at 2700rpm. trans and TQ conv are new 10/2010. 1800 stall. Any idea what might be wrong? tach and speedo are correct. thanks. also anyone do a 200r4 swap for a 69 firebird?
Old 11-11-2011, 09:28 AM
Rustydawg's Avatar
Cruzin w/Elvis in Bigfoots UFO
Something is way off here. You say that the tach and speedo are correct, but if this is in fact a 3.55 gear, with a converter that is relatively tight, 3500 RPM is out to lunch.
A couple of things come to mind:
The tach is set to 6 cyl.
The rear gear is more like 4.56.
The trans is not shifting into 3rd gear - it remains in 2nd.
Just for reference - a long time ago I had a Datsun pickup with a 4.38 gear and it would sit at 3600 RPM at 60 MPH, this with a 25" tire.
Old 11-12-2011, 12:01 AM
SSedan64's Avatar
Something's off ^^.
A 2004R will bolt in easily.
Same Crossmember.
Shorter DriveShaft with 32-Spline Yoke.
TV Cable and Brackets.
TCC Lockup Kit.
Old 11-12-2011, 06:49 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Originally Posted by SSedan64
Something's off ^^.
Same Crossmember.
TCC Lockup Kit.
typical 200-4r has a 27 spline output shaft
Old 11-13-2011, 08:21 AM
SSedan64's Avatar
Good catch Crosley, I must have had the 400 on my mind. why? I don't know.
trans swap, 400 trans in 83 elcamino? renagade Transmission - Rearend 2 10-07-2011 09:45 AM
chevy 400 turbo trans output shaft question 57shaker Transmission - Rearend 6 05-24-2011 06:05 PM
th 400 trans 81 el camino Transmission - Rearend 5 08-09-2010 05:56 PM
65 skylark turbo 400 trans. install question skylark65 Transmission - Rearend 7 05-09-2007 09:29 PM
GM Turbo 400 trans front seal housing question Gary Shugart Introduce Yourself 1 01-13-2005 02:56 PM
