T-400 transmission, no upshifts - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-27-2009, 07:53 PM
i have either a th375 or th400 tranmission and i bought a truck off my friend and it had this in it and supposidly the tranny is still good and i changed out the filter and refilled the tranny and it still wont shift does anyone have any ideas ----driving gears it has first u can put it in drive and it wont go past first gear and it also will start in any gear
Also my tranny has the pan of a TH375/TH400 and i dunno which one it is the tailshaft numbers are----865518c
Old 09-27-2009, 08:00 PM
83SILVRADO's Avatar
GROUND POUNDER
im no expert but it could have a burnt out clutch pack. time for rebuild...
Old 09-27-2009, 08:05 PM
could it be the vaccum modulator or the safety control switch or the transmission govenor
Old 09-28-2009, 04:42 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
yes, check them all.
verifiy vacuum at modulator,
check governor plastic gear under the 4 bolt cover near rear of main case
Could also be a stuck governor inner valve
Taurus transmission glitches... awbazar Transmission - Rearend 9 05-21-2009 04:34 AM
Transmission ID Elco68 Transmission - Rearend 10 01-13-2009 08:11 AM
1995 Impala Rebuilt Transmission Shift & Noise Problem Mobbvalous Transmission - Rearend 2 12-31-2008 03:50 PM
Need help identifying a Borg Warner T-10 transmission Federico Transmission - Rearend 3 08-04-2008 07:39 PM
Turbo 400 Transmission problem. Overheats 35chevrolet Introduce Yourself 1 07-08-2007 05:55 PM
