T-400 vacuum & kickdown hookups - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-02-2011, 06:06 AM
I'm going out to work on my old pickup next month & I can't remember how the trans vac & kickdown were hooked up. I transplanted a '70 Olds 455 & TH400 into this truck in the 80's while I was in high school. It's been sitting for the last 20 years & I've been trying to get it going again. The engine is almost ready to start up, but I still need to address the transmission.
One thing I noticed was the transmission vac & kickdown were off / missing.
How do I hook up a vac line from the engine to the trans? Where does it go (each end)?
As for the kickdown, I think the whole thing is missing. I think the wires may have been pulled out from the trans or cut off. How do I locate this, & how is it hooked up?
If you have any photos, that would be great.
Thanks.
Old 10-02-2011, 07:28 AM
Just connect a manifold vacuum line to the modulator on the trans.
for the down shift, th400's use an electric switch with a 12V input to the trans.
I have a picture in my album.
You can start and drive the engine without the down shift connected (for now).
Old 10-02-2011, 08:58 AM
Ya, the downshift was never hooked up since the engine was installed.
If I remember correctly, transmission fluid was get sucked thru that vac hose. I guess I need a modulator too.
Old 10-03-2011, 04:04 AM
SSedan64's Avatar
Kickdown Info >> T-400 kick down hook up question
Old 10-03-2011, 05:43 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Thanks.
The terminal can be seen at the upper right of the photo below. From HERE, Post #17:
Old 10-03-2011, 02:11 PM
Great info guys!!
I think I'll get a new modulator as well.
Thanks
Pontiac 400 and th400 vacuum question adam83 Engine 4 01-14-2011 06:19 PM
Pontiac 400 vacuum outlet question adam83 Engine 8 10-16-2010 12:35 PM
turbo 400 kickdown? hougie Transmission - Rearend 5 09-04-2007 11:59 PM
Vacuum hookups Yub350 Engine 3 10-21-2004 02:26 PM
Proper vacuum line hookups 66Caprice Engine 2 07-18-2004 09:52 AM
