T-400 vacuum line Identification - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-24-2012, 08:01 PM
Last journal entry: 76
I have a TH400 transmission and I am wondering what the 2 vacuum lines on the transmission are for.
thanks in advance
Old 03-24-2012, 08:07 PM
SSedan64's Avatar
#1 is a Vacuum Modulator, it should be connected to Full vacuum port on the Intake Manifold. Normally between the Carb & Distributor on a Runner.
#2 is a Vent for pressure to escape from heat build up.
Old 03-24-2012, 08:10 PM
Thanks for the quick reply I was right about 1 but not 2 thanks a lot
Help! Brake Line Lock Identification firebirdta84 Suspension - Brakes - Steering 1 08-22-2011 06:47 AM
Vacuum line What's best??? chevy3600 Hotrodding Basics 2 02-16-2008 11:23 PM
where is best for vacuum line? sabino56 Engine 29 12-02-2006 03:58 PM
Vacuum Line? USMCDCC Transmission - Rearend 16 05-15-2003 05:53 PM
ok to use same vacuum line for vacuum advance and tranny vacuum modulator? brian400ex Engine 4 02-19-2003 02:25 PM
