T-400 vehicle towed while in gear :( - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-14-2013, 10:59 AM
zildjian4life218's Avatar
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
So about 5 years ago I bought what I thought was a recently rebuilt TH400 with about 5-10 miles on it. The guy I got it from gave me the packages of the rebuild and shift kit that he put into it (can not remember brand right now). Well I found out that the guy I got it from bailed on it because the original owner had towed the vehicle about 10 miles with the transmission in gear. They said you could barely keep your hand on the case it was so hot. I planned on pulling the pan and maybe pull the pump out and inspect the clutches but what should I be looking for besides burnt clutches. I do not know what gear it was in but it was not in neutral.
Thanks for the input
Old 05-14-2013, 07:07 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
The T-400 works on hydraulic pressure. Engine must be running and turning the converter of the T-400 trans for the trans oil to be circulating in the T-400 trans.
With the shifter out of park on the T-400 , the T-400 trans is in neutral no matter where shifter is placed with out the engine running to create fluid pressure.
There is no lubrication on the T-400 trans with out the engine running.
The T-400 will not be in ANY gear with no hydraulic pressure.
Look for burned frictions & bushings in this T-400
The Following User Says Thank You to Crosley For This Useful Post:
zildjian4life218 (06-25-2013)
My T-400 Tranmission Will not go into any gear. Mrboykin0 Hotrodding Basics 7 10-24-2012 08:49 PM
T-400 hard to get into gear. jak327 Transmission - Rearend 2 04-27-2010 11:04 PM
Towed vehicle now it won't stay running toddiyaayas Engine 7 10-19-2009 02:19 PM
400 searching for gear price Transmission - Rearend 1 07-18-2007 11:17 AM
They towed my pride away Nightfire Hotrodders' Lounge 8 05-04-2006 09:16 AM
