T-400 vent tube broken off. - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-04-2010, 01:35 AM
junior stocker's Avatar
I just picked up another TH400 for a future project. It had just been rebuilt, and a shift kit installed. It's clean, inside and out, and I've replaced the front/rear seals, and filter/pan gasket. However, the vent tube is broken off in a spiral shape that barely protrudes from the case. What's the best way to get it out without damaging the case? I don't want to "experiment, and mess it up. Thanks, Butch/junior stocker.
Old 04-04-2010, 03:27 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
IIRC, the vent is just pressed into the case.
If you thread a screw into the opening of the broken tube, it should pull cleanly out. Don't thread it any more than necessary to get some 'bite', not talking about tightening the screw all the way, here. Just gently, enough to get a purchase on it.
From those shown, a small wood screw is what I'm talking about here, like those at the top right:
Old 04-04-2010, 07:21 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
pull the pump out... install new vent tube , bolt the pump back in
Pump easily comes out , no need to pull the pan off
71 Cutlass Differential Vent Tube vickraft Transmission - Rearend 2 04-20-2011 02:29 PM
Rear end Vent Tube? vickraft Transmission - Rearend 1 04-17-2011 07:42 AM
Vent tube location on T-350 Madmax305 Transmission - Rearend 11 04-05-2011 10:41 AM
broken th350 vent tube. bdbaggr Transmission - Rearend 6 09-19-2010 11:20 PM
350 turbo vent tube gaino Transmission - Rearend 2 09-05-2004 05:49 PM
