T-400 whine noise problem - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 07-15-2011, 07:58 AM
BBC BBC is offline
Gonna hijack here for a moment, anglia, this is why I was asking him because I'm now getting this whining noise, goes away as soon as things warm up, I did not use any large hose clamps as was suggested to align the pump half's, but I can say with confidence it was well and truly lined up when I put it together I spent some time on it making sure as it was obviously important.
  #17 (permalink)
Old 07-16-2011, 10:07 PM
gm pump
you have to use a alignment strap,some guys put the pump backwards in a empty case to align it then tighten the bolts.the stator shaft has to be centered with the pump gears
  #18 (permalink)
Old 07-17-2011, 06:10 AM
UngerMarkus's Avatar
Tuck´n´Roller
Hi guys!
I removed the pressure regulator and the valve body again. I inspected the valves again. There were no burrs, but some of them showed minor signs of friction. As if some spots were polished. I treated the valves with 2000 grid sandpaper soaked in ATF. Put everything back together and went with a TransGo Shift Kit this time. How it works perfectly!
T-400 or 12 bolt noise dilemma hgdmartin Transmission - Rearend 6 09-15-2012 03:49 AM
T-400 Valve Body Problem and whine UngerMarkus Transmission - Rearend 5 04-22-2011 12:49 PM
Pontiac 400 engine noise Purserrobert Engine 1 06-26-2008 09:15 AM
sbc 400 front engine noise jackfrost51 Engine 6 05-18-2006 03:37 PM
fresh gears with a little whine problem or not 75sprintguy Transmission - Rearend 4 02-21-2006 08:02 PM
