T-400 won't shift - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-07-2009, 07:52 AM
T-400 won't shift
Hey folks...I did some searching but still have a question. I'm building a 48 chevy p/u with a 355/th400. The tranny didn't want to shift out of 1st. I'm going to check the vacuum tonight to make sure that isn't the problem but I was wondering...I don't have the proper hookup for the kickdown so I just left it off completely. Would the fact that there isn't a connection at all affect the shifting? If I'm not going to use the kickdown should it be grounded? I'm hoping all I'm looking at is poor/no vacuum as far as the shifting goes. Thanks in advance for your help.
Barry
Old 07-07-2009, 08:10 AM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi,
If the modulator valve isn't the cause, check the governor it has a plastic gear on it that wares out & cause it not to shift.
Rich
If you don't hook up the detent you will need to manually shift it to second gear when you need more power to pass something
Old 07-07-2009, 08:19 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by richard stewart 3rd
Hi,
Rich
Dollar to a donut Richard is correct w/the governor gear. It'll stay in first, no matter what you do. It's an easy fix, fortunately. Just drive out a roll pin, and reverse to reinstall. Finding a new gear isn't hard, either. Most any tranny shop will have them. Prob. set you back <$20.00 TL, possibly less.
Remember to place a pan under the cover to catch any fluid. , you can reseal w/RTV if need be.
Old 07-07-2009, 04:17 PM
tnsmith10's Avatar
when will it rain???
Barry
as far as a no shift condition goes on a th400, it could also be because of a faulty kickdown solenoid, but just fyi, you can run the trans without the kickdown plugged in, it just wont have passing gear.
as far as it possibly being a modulator/no vacuum issue, the trans will still shift, just really late and firm. but normally its a govenor issue. either the valve is stuck, or the gear has been apple-cored. if the govenor is free and the gear ok, id suspect a bad kickdown solenoid. gl
Old 07-08-2009, 04:58 AM
I pulled the line off and I have vacuum. I started it up and took it up the road again just to check. I tried shifting manually and letting up on the gas and gunning it and it did shift into 2nd so I'm kind of leaning toward the modulator. They aren't expensive so I will probably get a new one regardless. I'll do some more experimenting tonight. Thanks.
Barry
Old 07-09-2009, 04:51 AM
Bought a new modulator yesterday and installed it lastnight. Truck shifts perfectly now!!! I love $14 fixes!!!!!!!!!!!!!!!!!!!!!!
my turbo 400 won't shift!! skylark65 Transmission - Rearend 2 07-01-2007 07:58 PM
Won't shift 2 Zeater1 Transmission - Rearend 4 08-17-2006 06:46 AM
Won't Shift Zeater1 Transmission - Rearend 3 08-16-2006 05:27 AM
turbo 400 won't shift out of 1st gpeak Transmission - Rearend 7 10-12-2003 08:52 PM
It Won't Shift! adryan16 Transmission - Rearend 4 12-12-2002 05:43 PM
