T-400 yoke problem - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 03-30-2012, 02:06 PM
Last journal entry: 76
might have to do that speed bump because I am not finding any long enough
but the yoke I have takes a 3r u-joint so I bought a 1310 to 3r conversion u-joint will I still need that and my old yoke?
  #17 (permalink)
Old 03-30-2012, 02:54 PM
The yoke I have is about 7 3/4 from the centerline of the joint to the end of the spline, so that's about 6" of machined seal surface. It does take a 1310 joint so your conversion joint would work but the seal surface is 1.890 or there abouts. I may have a housing that will work but I'd have to dig through my junk. Let me know.
  #18 (permalink)
Old 03-30-2012, 05:00 PM
yea that sounds about right my driveshaft is a 1310 also so I could use a straight 1310 u-joint with that but how would I go about getting that from you?
  #19 (permalink)
Old 03-30-2012, 05:49 PM
Send me a PM if that seal surface diameter etc. is right for you.
  #20 (permalink)
Old 03-30-2012, 07:08 PM
prostreet6t9's Avatar
Differential/Driveline
The large dia seal surface in 1.875.
  #21 (permalink)
Old 03-30-2012, 09:57 PM
yea the yoke I have is perfect the Tail housing is just for the 1.688 and I needed the tail housing for the 1.8
  #22 (permalink)
Old 03-31-2012, 09:50 PM
Wiki Edits: 85
I don't think a stock 9-1/2" tail exists with 1-7/8" bore. I know that stock tails 7" long do not exist with any bore.
  #23 (permalink)
Old 03-31-2012, 09:53 PM
7 3/4 do I have to cut a 1/2 or so off I have the yoke just gotta get a new tail housing
  #24 (permalink)
Old 04-03-2012, 04:00 AM
Wiki Edits: 85
Then you have the only one in existence. In the thousands of 400s I have owned I have never seen one. Neither has a competitor of mine who has been in business for over 50 years.
What is the casting number on your tail housing?
  #25 (permalink)
Old 04-03-2012, 05:57 AM
i will look at the casting the yoke is not factory it is 7.x inches I dont remember exactly I would have to look.
  #26 (permalink)
Old 04-03-2012, 07:14 AM
rick 427's Avatar
Last journal entry: 33 WILLYS
you say the yoke ''slides' over the output shaft in your 1st post...does that mean it ''splines'' onto the shaft,or ''slides'' over it.....makin sure you don't have a TH375 trans here...
  #27 (permalink)
Old 04-03-2012, 02:22 PM
Sorry my mistake it splines over the shaft.
turbo 400 yoke pfc allen Transmission - Rearend 4 12-21-2009 11:50 AM
tubro 400 yoke dmarcum123 Transmission - Rearend 4 10-22-2007 03:38 AM
What about a slip style t-400 yoke? baddbob Transmission - Rearend 1 03-17-2007 11:12 PM
Turbo 400 yoke question...? Bumpstick Transmission - Rearend 8 12-25-2005 02:41 PM
400 yoke question TASHAN Transmission - Rearend 2 07-17-2005 08:26 AM
