T-5 behind SBC - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-26-2002, 11:37 AM
Maverick's Avatar
Post T-5 behind SBC
Iam trying to decide on tarnny's for my '49 Chevy truck. I have a SBC 305 (It was free!) that Iam going to put in it. Since the motor is such low torque I want something with more the 3 gears and no computer. I would like a 700R4 auto but those are hard and expensive to come by. So Iam looking into and T-5 out of a S-10 or maybe a Manual out of a full size truck. Will the T-5 mount to the SBC? Any suggestions on what I should use?
Thanks!
<img src="graemlins/pimp.gif" border="0" alt="[pimp]" />
Old 08-26-2002, 10:00 PM
Post
You should be able to get a T-5 out of a late 80's camaro to fit with no problem.
Old 08-30-2002, 08:02 PM
Joe S's Avatar
Post
I beleive that the 4.3 S-10 will bolt up to your 305. shifter is in the middle of the trans were the Camaro shifter is at the rear of the trans. S-10 is easier to find but weaker than v-8 Camaro.
Old 08-30-2002, 10:24 PM
Post
I disagree with the S-10 trans being weaker...
The S-10 trans(also came in a full-size 4.3 powered p/up) is a Getrag NV3500. This tranny is pretty rugged. They are pretty expensive and hard to find in salvage yards. They have an integral bellhousing...all one piece.
I am currently building a '32 Tudor sedan with a '62 L79-style 327, and I chose the Getrag for this car, like mentioned above the shifter is further forward. Very rugged construction on this trans.
Old 08-31-2002, 04:17 PM
Post
Even a 305 will make a T5 blow chunks...
Old 09-02-2002, 08:57 PM
Post
the newer V6 camaros have a version of the T-5 in them.
Old 09-07-2002, 01:35 AM
deuce_454's Avatar
Post
the t-5 works fine up to about 250 hp, remember they came on mustang 5.0īs aswell and as long as you stick a 305 infront and dont speedshift like a 16 year old at his first race, you should be just fine for about the first 100.000 miles. and you have the 33% overdrine in fifth, i would go with the t-5
Old 09-09-2002, 11:51 AM
johnsongrass1's Avatar
Race it, Don't rice it!
Post
Ive been running the new t-5 for three years under 410 horse and 375 ft lbs or torque! Banging gears with a BM shifter. Even running 12'2 in the Qtr every other weekend!!
Old 09-09-2002, 12:14 PM
Maverick's Avatar
Post
Thanks johnsongrass! What was that T-5 out of??
Old 09-09-2002, 12:42 PM
Last journal entry: Doors
Post
I would recomend a 200 R4 they arent bad like the early 200's metricks. They have over drive so they are a 4 speed, the drive shaft is the same as for the turbo 350 but you will need a cross memeber from a turbo 400, and you can get one for under 150 bucks working. It would give you great results and the overdirve is a little higher then on the 700 R4. They are also reated for well over 425 hourse power, so i read
Old 09-11-2002, 02:41 PM
Post
Hey, Sorry for the long wait before answering. Got really busy chasing an electrical problem! The T-5 came from an 88 Camaro V-6. Although the V-6 and V-8 interchange phsyically the 6 has slightly lower 1,2,3, gears. The 6 also has a diffrent mount than the 8. Both will still bolt to the tranny, But be sure you get the V-8 style crossmember, The T-5 in the Fords aren't tilted to the side as they are in Chevys for tunnel clearance.
Old 09-17-2002, 10:22 AM
farna's Avatar
Last wiki edit: AMC V-8s Last photo:
Wiki Edits: 14
Wink
You can use the 700R4E without the computer. You will need a pin-out of the electric connetor and can then make a simple switch box. Use a four position rotary switch (Radio Shack sells a six position, it can be used) to change gears, and a toggle switch to activate the lock-up converter. I did this with an all electronic Jeep AW4 and it works great! Just dial your gear like selecting channels on an old fashioned TV set. All you do is run power to the solenoids for the correct gear. You will need some diodes to keep power from feeding back in some gear positions. Two solenoids control the four forward gears, one controls the lock-up converter. On the Jeep tranny the converter won't lock up in first, so I just make sure I put the selector in first just before stopping and leave the converter switch on all the time. I think the GM trans is the same way. The Jeep tranny provides engine braking only in third and fourth when in drive, so no problem there shifting down (engine braking in second and third when selector is in the "3" position). So you still haveto have a lever selector, but change gears with the switch once in drive. Lever selector can be a standard shifter or something simple and unobtrusive like an old Corvair dash mounted lever. A lawnmower throttle control could probably be adapted.
