Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - T-5 Dust shield question
Old 06-02-2004, 10:03 PM
DoubleVision's Avatar
DoubleVision DoubleVision is offline
far as I can tell, you`ll only have to remove the starter to install the dustshield, then it just bolts on to the tranny`s lower bell housing, replace the starter and it`s done. the tranny wouldn`t need a upper dust shield, the block is the dust shield, any open area is subject to dust and other debris as well, so no, a upper piece would not be needed since the bell housing sits flush on the block.
