Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - T-5 Experts...
Thread: T-5 Experts...
Old 07-18-2012, 11:01 AM
timothale timothale is offline
Wiki Edits: 27
redrill
As long as there is enough metal thickness you can redrill and tap. Make sure the trans front bearing retainer, throw out bearing sleeve is a good tight fit then use a transfer punch to get the location dead on, drill a small pilot hole and work up to the size for your tap. My brother had a shop that did a lot of jeep V 8 conversions did a lot of stuff not in the instructions to make things work.
