T-5 installation in 55 Ford car - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-19-2012, 10:50 AM
I purchased the drivetrain from a 1994 Mustang (5.0 liter engine and 5-speed transmission) for my 1955 Ford Customline (car). I am concerned that the shifter location will be set back to far for comfort. I am looking for advice from other who have completed this swap. Is the shifter location akward - meaning located too far back? If so, how did you correct it? Did you have to install a different tailhousing? I am hoping that I don't have to mess with the transmission. Advice? Thanks in advance for your advice.
Old 05-19-2012, 11:04 AM
Sounds like you need the tailhousing from a T5 out of an S-10. The shifter is much further forward on those. The swap is relatively straightforward and well documented on the web - just use Google.
Old 05-20-2012, 08:47 PM
S10 Racer's Avatar
http://www.warsprints.com
Just a little word of wisdom. If that T5 is a factory tranny, be easy on it. They will not take much abuse.
Old 05-20-2012, 09:14 PM
t5 in 55
i modified the shifter,by making a bracket to mov it forwerd,as the shifter was short and bolted to the stick,it worked ok,not as firm as the original setup.also made a adaptor to fit on the yblock useing a 4speed bell housing.re prev. poster saying the t5 is weak the yblock was bored 292 to 312bor and a mild cam so it had a lot mor torq than a 302.drive it sanely and it will work
Old 05-20-2012, 11:10 PM
S10 Racer's Avatar
Yes, the T-5's are weak in stock form. I replaced four of them within a year in a 93 GT Mustang. Anything will break if abused. Drive it right and it will last.
Old 05-21-2012, 09:42 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Some links to T5 info here.
Unisteer installation on 32 Ford OU812 Suspension - Brakes - Steering 9 10-02-2012 07:54 AM
Watch Car Lift Installation Bobs36ford Hotrodders' Lounge 0 11-03-2011 02:53 PM
street car wiring,rear battery installation lightningboltz3 Electrical 1 02-23-2007 06:14 PM
47 Ford Radio installation DANP Interior 3 10-16-2005 10:20 PM
ford 8 installation techniques?? voodoosurfer Transmission - Rearend 1 05-02-2005 11:59 PM
