t-5 speedo conversion - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-29-2008, 01:56 PM
has any one changed the electronic speed sensor in a t-5 to a gear driven one ?the trans needs 2 b rebuilt anyway so its coming apart.thanx jim
Old 03-29-2008, 08:20 PM
judd55's Avatar
I used these two resources to do the math and had a Trans shop do the deed..........T5 Speedo Hanlon T5 also needed an earlier model tailshaft as the bullit hole is larger on the Electronic drive.
Old 03-30-2008, 01:01 AM
Wiki Edits: 85
More importantly, the alignment of the speedo hole is different than the sensor hole. The sensor hole aligns dead center to the output shaft, the speedo hole aligns to the side of the output shaft.
Old 03-30-2008, 10:22 AM
judd55's Avatar
QUOTE]More importantly, the alignment of the speedo hole is different than the sensor hole. The sensor hole aligns dead center to the output shaft, the speedo hole aligns to the side of the output shaft.[/QUOTE]
Yup sorry, neglected to mention that.............bottom line is you need an earlier gear drive tailshaft. If you can get one cheap enough it's less costly than the alternative, a conversion kit Cable X $300
speedo conversion timberjack Transmission - Rearend 1 01-19-2008 11:24 AM
Help needed with speedo on a 327 to 350 conversion. Oolong Transmission - Rearend 6 09-24-2006 05:53 PM
Speedo Conversion birdman891 Electrical 3 04-07-2005 05:11 PM
85mph monte carlo speedo to 120mph conversion 406 ss monte Transmission - Rearend 0 01-31-2004 03:19 PM
Hotrodders Knowledge Cluster: Disc Brake Conversions Jon Suspension - Brakes - Steering 0 08-29-2003 03:34 PM
