Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - t-5 swap
Thread: t-5 swap
Old 02-13-2005, 09:27 PM
OneMoreTime's Avatar
OneMoreTime OneMoreTime is offline
Hotrodders.com moderator
Wiki Edits: 3
manual swap
Installation of the tranny is basically R&R..using the camaro bellhousing..the clutch linkage and pedals I woudl look for a chevelle that had a stick in it and grab the bracketry pedals and linkage from that..then it is a matter of hooking up the clutch so it works..Shifter should come with the tranny if you got it from a yard..
I am not sure on the driveshaft if that is the correct length or not..guess you will find out..
Very doable and common type of swap..I have done this sort of thing on Fords..the basic deal is the same on a chevy..
OMT
