T-5 tail shafts - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-17-2007, 10:54 PM
bluestang67's Avatar
Last journal entry: rear end detail
T-5 tail shafts changed for shifter location
I have a 90 gt T-5 with the shifter located on the tail shaft. I seen a F150 truck T-5 with the shifter mount closer to the gear box . I was wondering if i could use that tail shaft to this trans. My problem is i'm trying to get the T-5 in my 31 Model A sedan. The tail shaft shifter ends up under my seat location because its 26 inches from where bellhousing mounts to engine. The F150 pic looks as if it would move shifter up at least 8 inches or more .
I would use the F150 if i could get the first gear ratio changed out to match the 90 GT T-5
second pic is of T-5 first is of a trans with shifter in best position .
Old 03-18-2007, 04:36 AM
Last journal entry: getting the loose ends done
tail shaft
i ran into the same thing when i use camaro trans for my truck the only thing i changed was the tail housing from a s10 did not change the shaft but you have to move the speedo gear on the shaft. thats if you can swap tail shaft housings
Old 03-18-2007, 07:52 AM
Yep the new parts hot rodding has to be sceinced out . Be nice to have parts laying about or a bud with a full yard.
Old 03-18-2007, 08:10 AM
The Chevy S10 tailshaft housing has the most forward shifter position, but I'm not sure it will work with the Ford T5. The Ford and GM ouput shafts use a different spline count, so are the yoke diameters different? That could mean different tailshaft bushing sizes. I'm pretty sure that your Ford T5 is a WC transmission, which means you'd need a WC S10 housing. They were used in - I think -'93-'94. The speedo drive location has already been mentioned. These are just things for consideration, but can cause some grief if not resolved beforehand.
Bob
Old 03-18-2007, 08:24 AM
Bob yes its a WC . Not being a trans guy here at all i see the speedo in the housing . So what your saying is i would have to take out some internals to move its location . As for 93-94 S10 there are a few in local yard with trans in them . Should i look for a specific number on the tag to see adaptablity or ID for a WC T-5.
Old 03-18-2007, 02:48 PM
First, all S10 WC transmissions will have an electronic speed sensor instead of a gear driven speedo. There's a 40 tooth reluctor on the tailshaft that provides a signal pulse. I seriously doubt that the sensor location would coincide with the Mustang location, so you'll have some work to do on that. I have a WC S10 trans and the tag number is 1352-216.
Bob
Old 03-18-2007, 06:35 PM
Bob your right went to a swap meet today found a 89 T-5 from a 4 cylinder S10 . The tail shaft and top plate to relocate shifter forward worked well . I think i have a remedy to move the electronic reluctor over to my shaft . The out put shafts look identical but im not experienced enough to pull it down that far and switch them .
The only difference i see in the gear box is the for most gear its smaller in the S 10 versus the WC first gear box pic is of 90 mustang second is chevy S10
So i now have a WC T-5 5spd with a shifter that will work in a 31 Model A
ID:	19586   Click image for larger version
ID:	19587   Click image for larger version
ID:	19588   Click image for larger version
ID:	19589   Click image for larger version
Old 03-18-2007, 06:39 PM
Pic of finished trans for the 31 Model A shifter will be in the front of seats by about 4 inches now .
Old 03-19-2007, 03:41 AM
t-5
glad i didn't tell you that!!!!!!!!!!!
Old 03-22-2007, 05:37 PM
50 chevy you did tell me that and it got the ball rolling
Here is what it looks like sitting in the 31 Model A fits nicely .
ID:	19718   Click image for larger version
Need Tail Panel Help! Please stereodud Body - Exterior 2 05-26-2005 09:56 PM
tail pipes or no tail pipes? 92camaroZ28 Engine 13 01-12-2005 11:58 PM
tail lights screwed. need help 406 ss monte Electrical 6 12-26-2004 08:04 PM
Wiring Tail Lights & Turn Signals horvath Electrical 15 04-30-2003 05:04 AM
Can you swap tail shafts on TH350s? briwill Transmission - Rearend 5 12-11-2002 08:36 PM
