t-5 tranmission hard-impossible to shift - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-22-2007, 04:51 PM
BMM BMM is offline
Hello. Last night my 1991 Mustang 5 speed decided it would not shift. Try as I might, it wouldnt go into a drive gear. It wouldnt grind, but wouldnt go. I could get it into reverse, but it would grind extremely and stall. Today I shifts, albeit with some force, and every once in a while gets really tricky.
Ive described it as having make some funny grinding noises before.
What could this be? Total tranny problem, or something small? Please help!
Old 02-22-2007, 04:54 PM
1931 steve's Avatar
Last wiki edit: How to rebuild an engine Last photo:
Wiki Edits: 4
Will it shift OK with the engine not running? If so it sounds like it could be a worn out clutch.
Steve
Old 02-22-2007, 05:08 PM
BMM BMM is offline
Its seems to shift alright with the engine off, a little snag every odd shift though. I just took it out quickly...the symptoms are so haphazard. It'll shift fine one time, than get stuck the other etc. It is making alot of funny noises, especially when the clutch it depressed, and when shifting.
Thank you.
Old 02-22-2007, 05:33 PM
aka Duke of URL
Sounds as the release bearing asm. is hanging on the trans. front bearing retainer. Common problem. Replace the bearing retainer with a steel one.
Old 02-23-2007, 01:56 AM
BMM BMM is offline
Will do (or a shop will, at least). Thank you.
Hard Shifting 97 Suburban JCPSME Transmission - Rearend 5 07-16-2005 01:23 PM
98 Blazer Shifting Hard After Long Trip Ghetto Jet Transmission - Rearend 5 06-28-2005 09:41 PM
TH700r-4 shift kit 85CHEVY Transmission - Rearend 6 11-14-2003 10:18 PM
TH-350, low rpm 1/2 shift gearhead_383 Transmission - Rearend 7 10-30-2003 09:52 AM
Tranny shift problems. chevcamz28newbie Transmission - Rearend 6 08-09-2003 06:52 PM
