t-5 transmission
I am looking for a good GM t-5 from an S-10 to mount behind the inline 235 in my '51 Chevy. I need a unit from a 2.8 v-6 truck. Anyone out there have one or any good sources? I live in Ohio
every junkyard thats still open. the 2.8 5 speed was the most common combo ever used in the s10's...... the 4cyl trans has better gear ratios....will make it alot better out of the hole then the v6 trans
Thanks
I'll consider the 4cyl. trans. |
Here's a link to all the info you might ever need on yout T5 swap.
TRANSMISSION - T5 Tech Links - THE H.A.M.B. |
I used a 4 cyl T5 trans behind my 283 in a 56 chevy truck. They are not very strong so don't beat on it.:)
non of the t-5's have any gurth to them, if your looking for a hot rod t-5 your going to need to shell out the bread for a tremec
| All times are GMT -6. The time now is 07:58 AM. |
